Each head light are have their individual circuit from the switch - relay - fuse -ground.
1) First check fuse 2) listen if H/L relay can be heard when turning on the switch also when Hi beam is pulled 3) check light switch wire colors (pink) and (pink/blk) if shows 12v when the HL switch at On position
